Munchkin Venting
ChrisL
ChrisL Member Posts: 121
I am considering venting a munchkin with the pvc going up inside an outside wall before terminating maybe 15' up above ground. Has anyone had any noise problems with this kind of install?
thanks,
ChrisL
  • Bryan_16
    Bryan_16 Member Posts: 262
    not sure
    exactly what you are trying to do, but vent noise on a Munchkin is virtually non-existent. You will be ok.
  • Tom Simensen
    Tom Simensen Member Posts: 74
    Expansion
    PVC will expand quite a bit. Don't make your holes too small, leave a little room for expansion and contraction, and you should be fine.
