Munchkin Venting
ChrisL
Member Posts: 121
I am considering venting a munchkin with the pvc going up inside an outside wall before terminating maybe 15' up above ground. Has anyone had any noise problems with this kind of install?
thanks,
ChrisL
thanks,
ChrisL
not sure
exactly what you are trying to do, but vent noise on a Munchkin is virtually non-existent. You will be ok.0 -
Expansion
PVC will expand quite a bit. Don't make your holes too small, leave a little room for expansion and contraction, and you should be fine.0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
