101A Water Feeder
Tom J.
Tom J. Member Posts: 2
Using a float type low water cut-off on a new steam boiler with a 101A Water Feeder. What is the proper location for the cold water inlet to the system from the feeder?
Thanks in Advance,
T J
  • oil-2-4-6-gas
    oil-2-4-6-gas Member Posts: 641
    dont feed cold/// tap into the domestic hot and run that for you freshwater feed
