101A Water Feeder
Tom J.
Member Posts: 2
Using a float type low water cut-off on a new steam boiler with a 101A Water Feeder. What is the proper location for the cold water inlet to the system from the feeder?
Thanks in Advance,
T J
Thanks in Advance,
T J
dont feed cold/// tap into the domestic hot and run that for you freshwater feed0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
