Covered patio heating
Empire_2
Member Posts: 2,340
I believe that you should consult contractors in your area that can properly control this environment (Patio). Condensation on the windows may be a factor espically during cooler nights.
I need some help in finding some type of ceiling-mounted space heaters for a covered patio. The ceiling height is 9'6" and the architect doesn't want any type of heater that is mounted on a "lamp post"---like the decorative post with infrared heat. The patio is open on 3 sides and is attached to a pool house.
I haven't found an infrared heater that will have the proper top clearance yet. The architect says that if we can't find a gas-burning heater that will work that we will need to go with electric.
This is not an area that will be used a lot, so something like radinat floor doesn't seem to be an answer.
What are your thoughts?
Thanks in advance,
Tom Atchley
Ft. Smith, AR
Why not consider
hydronic based radiant ceilings? Check Wirsbo for details.
ME
Low intensity gas radiant tube heater
is probably what you want. A few smaller models can be mounted at a 8ft min with 6" clearance to the ceiling.
Checkout www.detroitradiant.com0 -
Sterling
How about something fast acting with high output like a Sterling panel for the overhead?
Chris0 -
Space-ray
Spaceray has a Cold Blocker model.
www.spaceray.com
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 966 Plumbing
- 385 Solar
- 15.3K Strictly Steam
