Decorative/ Small/ Wall Mount Steam Radiators
Doug Wagoner
Doug Wagoner Member Posts: 78
why not cut the pipe 2 feet above the vanity you want to install and offset the floor penetration to clear the vanity and make your self a "towel warmer"?
  • Tom_22
    Tom_22 Member Posts: 108
    Selection and Finding Steam Radiators
    In hot water, there are all kinds of decorative and designer radiators. Do such things exist for steam? I would like to put some small radiators in bathrooms that currently have a heat riser pipe. There is very little room to install a radiator anywhere... I was considering something wall mounted.
    Could anyone direct me to where I might find a selection of small and preferably decorative and modern looking steam radiators? Tanks, Tom
  • bob young
    bob young Member Posts: 2,177
    you could always use a two foot section of cast iron baseboard. c.i. free standing radiators are back in vogue.
    Steamhead Member Posts: 18,498
    They make modern ones
    go to www.steamradiators.com to see the two I know of. I haven't used them, but I think Alan Forbes (California Radiant Wizard) did and they worked well for him.
    Consulting
  • Tom_22
    Using baseboard
    Hi Bob,
    I was thinking of that. I have very little space around the base of the bathroom though. I was thinking of mounting it high on the wall, but I'm afraid the room might not heat very well that way. Any thoughts on a high mounted radiator?
    Another thought I had was to mount it inside a new vanity I want to install. The vanity would keep the heat from circulating though. I wonder if I made a hole in the side of the vanity and a couple of holes in the doors and put decorative screen in the holes, if the room would warm up OK?
    The bathroom has a 2" heat riser pipe now acting as a radiator. It works OK but it rises in a corner and I would like to install the largest vanity I can fit (about 30" wide) and the riser pipe would prevent it from going all the way into the corner.
    TomBk
  • Tom_22
    Nice looking, but wow...expensive!
    Those are nice looking radiators, Steamhead. But they sure are expensive. Yikes!
    I'd like to be able to sell some unneeded conventional looking radiators I have for that kind of money. I'll probably wind up bringing them to the scrapyard.
    Tom
