Buderus LT160 HotWater
RoosterBoy
Member Posts: 459
hi what is the difference between the L160 and the LT160
I will be using the G115 28 with 2109 controller
thanks
thanks
The difference
The LT is to park under an oil fired and the L series is for under the gas fired.Other than that they are both 42 gallon and one of the top tanks that money can buy.
cheese0 -
L and LT Tanks
What Mike stated is true. The LT Tank comes with a bracket to mount the G115 Boiler to it (a bracket kit has to be ordered to mount a G215 boiler).
The L series tank is provide with two studs which line up with the gas boiler bottom bracket.
hi joe with my elictric rate at 0.727kwh i am running elctric now would the lt160 with g115 be still cheeper to run
then elctric hot water
electric vs oil
My best info says electric would have to be about 4 cents per kilo to equal oil. hope this helps. maybe someone else has more current info0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 945 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
