Buderus Panel Radiator
RoosterBoy
Member Posts: 459
can you put a leather couch in front of the buderus radiator i like the sleek look of them and i like the fact that i dont need long baseboards but my couch is in front of a window where the radiator will go i was hopeing i can have the radiator behind the couch out of the way
thanks
thanks
It will stifle
the output somewhat. The Buderus panel radiator puts out both radiant heat and natural convection heat. The radiant heat will be blocked by the couch. The natural convection part will still generate some heat. Maybe if you over size it it will be OK. WW
Bad application in most cases.
The couch will limit the ability of the air to convect in most cases. Also you will lose the radiant into the back of the couch.0 -
but...
you would have a hot seat!!!!! get it, in the hot seat hahahaha....... I know don't quit my day job...
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
