REFURBISHED RAD
JERRY_9
Member Posts: 9
CAN ANYBODY TELL ME WHAT A DECENT REFURBISHED CAST IRON RAD SHOULD LOOK LIKE? SHOULD I SEE RUST ON THE INSIDE OR OUTSIDE. WHAT SHOULD I NOT SEE? WHAT SHOULD THEY USE TO SEAL THE FITTINGS?
Hey Josh,
A refurbished rad needs to be pressure tested and guaranteed. These two are the most important. Rust on the inside can be expected, especially with a refurbished steam radiator. But, be they steam or hot water, flush the radiator before installing.
And if it is still rusty on the outside when you were expecting a freshly painted rad, then a better job of refurbishing is needed.
Radical Radiator0 -
Hey Josh,
Radical Radiator0 -
Hey Josh,
REFURBED RADS
WHAT SHOULD THEY USE TO SEAL FITTINGS?
I HAVE HOT WATER
THANKS0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
