SMALL GAS BOILER
RADIENTINVT
Member Posts: 1
LOOKING FOR GAS BOILER 260 OUTPUT FOOT PRINT 26 X 26 STANDARD VENT NOT CONDENSATING
I'd call that
a 1 match boiler.
Never seen anything that small. You might want to consider using a heat exchanger off the domestic water heater if it's available.
try RBI
I think they may be small enough.0 -
Thats got to be 260K otherwise he's talking about a Coleman lantern under a pot of water.0 -
Try Hydrotherm
They are hozizontal section boilers that stack upwards as they get bigger with a very small footprint. Factory support and backing is poor in my experience, leaving reps, wholsalers and installers holding the bag. Some contractors have seen extensive issues with burner failures with alumininized steel burners, stainless is now used. I have had some myself and the factory will not warranty the product.
Boilerpro0 -
Commercial boiler
Peerless GM-07 is 26.25" wide, 25.75" deep. Good old cast iron.0 -
Wall or floor
weil McClain makes a nice little cast iron wall hung, or it floor space is not a problem Dunkirk makes a nice small cast iron, follow the rules on boiler bypass piping with a 26K load or you will return too low a water temp or cycle too much.0 -
Small!!
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
