heat exchanging
Kent_3
Member Posts: 60
Does anyone know what kind of heat exchanger (air gap or not) is required in Alaska for a heating water/DHW application?
Depends
on you local jurisdiction whether a single wall HX is allowed. You will have to call your local inspector.
heat exchangers
The local inspector said to use the International Mechanical Code, which I cunsulted, but I couldn't
find anything about vented or unvented exchangers. Maybe this is in the International Plumbing Code book, which I don't have.0
- 120 Geothermal
- 169 Indoor-Air Quality
- 396 Solar
