dirty pipes in my house
RoosterBoy
RoosterBoy Member Posts: 459
hi I was wondering my town water has allot of sediments in it and my HVAC contractor will be installing a buderus g115 in 3 weeks.
what can I do to keep the water pipes clean in the boiler is there any good advice I can do to save my pipes from clogging up my system like a boiler cleaner or something
thanks
  • EJW
    EJW Member Posts: 321
    Water Filter
    Do you have a sediment filter on your main line filtering all the water for the house??
  • RoosterBoy
    no i dont if this will help i will have my hvac installer install one when he dose my boiler what kind should i get
    thank you
  • EJW
    Water Filter
    I use Aquapure. I also like to get the clear cylinder so I can see the cartridge at work. Depending on how fine or course you sediment is will determine the micron size of your filter cartridge. This will keep the sediment out of all the water lines in your home and your faucets will be much happier. You should also have the contractor flush the water heater out if it's not being replaced in your project. Hope some of this helps, EJW
