dirty pipes in my house
RoosterBoy
Member Posts: 459
hi I was wondering my town water has allot of sediments in it and my HVAC contractor will be installing a buderus g115 in 3 weeks.
what can I do to keep the water pipes clean in the boiler is there any good advice I can do to save my pipes from clogging up my system like a boiler cleaner or something
thanks
thanks
Water Filter
Do you have a sediment filter on your main line filtering all the water for the house??0 -
no i dont if this will help i will have my hvac installer install one when he dose my boiler what kind should i get
thank you
Water Filter
I use Aquapure. I also like to get the clear cylinder so I can see the cartridge at work. Depending on how fine or course you sediment is will determine the micron size of your filter cartridge. This will keep the sediment out of all the water lines in your home and your faucets will be much happier. You should also have the contractor flush the water heater out if it's not being replaced in your project. Hope some of this helps, EJW0
- 86.6K THE MAIN WALL
- 54 Biomass
- 98 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 931 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 42 Industry Classes
- 48 Job Opportunities
