lack of heat
Howard_2
Member Posts: 4
I have 2- 5 story buildings side by side with the boiler in the back of one building. The apartments furthest from the boiler get less heat because I do not have 28 inches-A dimension- on that steam main. Also I have a belly in the steam main of that colder line. The 5th floor apartment on this colder line does not have a riser in the bedroom and the livingroom, only in the kitchen and the bathroom. Because I have had banging, a plumber installed check valves on my drips on this colder main. I want to get these problems solved. Please help.
OK
1. Get a new technician
2. Educate yourself, at least minimumly, as to what to expect.
3. This is the first thing to read....
http://www.heatinghelp.com/newsletter.cfm?Id=130
4. Here's the next, if you like another.
http://www.heatinghelp.com/shopcart/product.cfm?category=2-109
5.And here's the bible....
http://www.heatinghelp.com/shopcart/product.cfm?category=2-3
6. Here's a sample of how much fun to read this is, it's my favorite.
http://www.heatinghelp.com/newsletter.cfm?Id=25
7. Here's more reading.
Noel
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 987 Plumbing
- 389 Solar
