Aird-Don Boiler
Saw a Aird-Don Company, Oil Boiler at a 9000 sq ft renovation in an old builing in Hudson, NY , had a large Swastika in the casting of the front section of the block. Has anyone seen or heard of this boiler, rating plate, jacket and controls were stripped... Has anyone heard of this,? Google couldn't help. Dan? Anybody?
Thanks,
Rick
    Steamhead Member Posts: 18,184
    Burnham might have made it for Aird-Don
    they had a line of boilers called the "Swasteeka". The sizes are listed in the Hydronic Rating Handbook and possibly in Beacon too (in the Library) so if you measure yours we might be able to size it from that.
    The Swastika was considered a good-luck symbol until Adolf Hitler started using it.
    Consulting
  • Supply House Rick
    Supply House Rick Member Posts: 1,399
    Aird-Don Boiler/Dan can you help?
    I will post pictures next week...
  • Dr. Hardcrab_2
    Dr. Hardcrab_2 Member Posts: 2
    Burnham Boiler with Swastika
    Just ran into one yesterday. Owner said it was installed back in the 1930s. It says Burnham boiler and then below it says Levittown(?) NY (It was definitely NY, but not sure about Levittown. Can't tell from the picture). It's about 5' tall (ntoice all of the asbestos!!)and has been "abandoned" for a newer Weil McLein. I'd like to ask the owner if I could have the front plate, but the house was built in the 1600s and he is going to turn it into a historic landmark (if the county will help) so I would think he would want to leave it there just to add to the 'history" of the house....
  • Dr. Hardcrab_2
    I received a reply from the good people at Burnham:
    Thank you for the email this fine Friday morning. This question does
    come up occasionally . You are correct in that we (BURNHAM ) were
    originally based in Irvington New York. We did have a boiler series
    known as the Swasteeka which at that time had a very positive
    connotation . World events did change the perception of the Swastika
    symbol hence this series was renamed.
    Dave King
    Technical Services Representative
    Burnham Corporation
    717-481-8400
    Thanks, Dave!
    (Notice i did not say "Atta Boy, Dave")
  • Swastika Symbol on Boiler
    Dave is correct as to our manufacturing facilities being situated in Irvington, NY. Back in those days prior to the two World Wars, the Swastika symbol was both a sign of prosperity and good luck. As a matter of fact, it dates back as far as 315 BC throughout Europe and Asia and was used by North American native Americans as well. It was used widely throughout the European countries on many products and is possibly the oldest known symbol in world history. If my memory serves me correctly, the original emblems had the configuration as a mirror image with the points in a counterclockwise direction. As Dave indicated, world events in the first half of the 20th century changed the connotation of the Swastika symbol somewhat. Hope this helps.
    Glenn Stanton
    Burnham Hydronics
  • Supply House Rick
    Thanks Glenn
    You ask ask Dave Benham, I am as loyal a Burnham guy as you can find. Keep up the great work!
  • Thanks Rick
    Here is a picture of an old Aird-Don boiler front section that I happened to come across behind an old barn in Schenectady, NY. Thanks for you support!
    Glenn
