F&T Traps for one-pipe steam
I have a job where I need to put in a condensate pump for a building that is one-pipe steam. I would like to know if the correct way to size the F&T trap is by the total load of the system, because it is one-pipe steam.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=216&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,687
    Yes,
    and you can split the load with parallel traps if that makes more sense.
    Retired and loving it.
  • gerry gill
    gerry gill Member Posts: 3,083
    why do you
    need to put in a condensate pump? just curious.
    gwgillplumbingandheating.com
