what is the control on top
D lux_2
D lux_2 Member Posts: 230
thanks
    Steamhead Member Posts: 18,205
    It's a flow-check
    to keep water from entering the radiators by gravity when the circulator is off. These are used on multiple-zone systems or on boilers having tankless coils.
    I'd check the radiation against the building's heat-loss to see if it would run in condensing range enough to make a Munchkin worthwhile.
    Consulting
  • D lux_2
    thanks steamhead
    all be doing H L tonight after smors and fire out side fall coming
  • Wayco Wayne_2
    Wayco Wayne_2 Member Posts: 2,479
    Smores sounds great
    Fall's defineitely coming. Sometimes Condensing boilers are useful if the heat emmitters are large oversized cast iron radiators that were installed with a gravity system. I've had some systems that can go as low as 140 degrees @ 10 degrees outside temps because of that particular situation. That leaves lots of room on the outdoor re-set for condensing temps for the boiler. Hey Steamhead! anything come of that referal I sent your way in Balmore? WW
    Yes it did
    I've been meaning to thank you so now is as good a time as any. I looked at the system and determined it needed some work. Owner will have the asbestos removed then call us to get his system going the way it should be.
    Consulting
  • Wayco Wayne_2
    Good show
    Thanks for taking a look. It's good to have someone good at his craft to refer to folks. WW
