what is the control on top
D lux_2
Member Posts: 230
thanks
It's a flow-check
to keep water from entering the radiators by gravity when the circulator is off. These are used on multiple-zone systems or on boilers having tankless coils.
I'd check the radiation against the building's heat-loss to see if it would run in condensing range enough to make a Munchkin worthwhile.All Steamed Up, Inc.
Consulting0 -
thanks steamhead
all be doing H L tonight after smors and fire out side fall coming0 -
Smores sounds great
Fall's defineitely coming. Sometimes Condensing boilers are useful if the heat emmitters are large oversized cast iron radiators that were installed with a gravity system. I've had some systems that can go as low as 140 degrees @ 10 degrees outside temps because of that particular situation. That leaves lots of room on the outdoor re-set for condensing temps for the boiler. Hey Steamhead! anything come of that referal I sent your way in Balmore? WW
Yes it did
I've been meaning to thank you so now is as good a time as any. I looked at the system and determined it needed some work. Owner will have the asbestos removed then call us to get his system going the way it should be.All Steamed Up, Inc.
Consulting0 -
Good show
Thanks for taking a look. It's good to have someone good at his craft to refer to folks. WW
- 86.7K THE MAIN WALL
- 56 Biomass
- 103 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 936 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
