\"Creative\" venting
Ken C.
Ken C. Member Posts: 267
A potential new customer had our company over today for a quote on making his ancient boiler heat-worthy. I couldn't help but notice that the gas-fired hot water heater had 4" flexible dryer vent (aluminum) going into to the chimney. I asked him who installed the heater, but I already knew the answer (hint: the intitials are H.D.). Sleep tight, Homer.
  • Tony_8
    Tony_8 Member Posts: 608
    I've seen that
    A couple of times already. I've also seen z-flex liner run to the 3 ft long b-vent that went through the roof from the water heater 12 ft away. It looked like a camel :o
  • harvey
    harvey Member Posts: 153
    same matierial as chimney liners. it's ok as long as there is proper clearance to combustables and pitched
  • H. Green
    H. Green Member Posts: 22
    Same Material?
    Product sold as a Chimney Liner is backed by the manufacturer, and is Listed by a recognized agency, for its intended application. Criteria imposed for Listing include thickness of material, permissable alloys, joint/lock design, bend radius, puncture resistance, thermal performance and adaptablility to appliance flues. Don't believe you have the same backing if you use dryer vent as a combustion vent.
  • Matt Undy
    Matt Undy Member Posts: 256
    same material??
    umm....I hope the liner doesn't have that horrible seam that unzips if you look at it wrong...
    Aren't chimney liners SS not aluminum?
    Matt
  • eric_2
    eric_2 Member Posts: 148
    MATERIAL
    Gas uses aluminim liners while oil uses SS liners.
    Neither use dryer vent.......;0)
  • Tony_8
    right.....
    Sure it's the same material, ALUMINUM. The "sameness" ends at 1/2 the wall thickness and NO approval for this application. When was the last time your Dryer vented at 450F ? I'm betting your wife would howl about THAT shrinkage !
  • curiousity kills
    curiousity kills Member Posts: 118
    I saw home HD install hydronic expansion tanks on domestic line to water heater on three occassions.
