\"Creative\" venting
Ken C.
Member Posts: 267
A potential new customer had our company over today for a quote on making his ancient boiler heat-worthy. I couldn't help but notice that the gas-fired hot water heater had 4" flexible dryer vent (aluminum) going into to the chimney. I asked him who installed the heater, but I already knew the answer (hint: the intitials are H.D.). Sleep tight, Homer.
I've seen that
A couple of times already. I've also seen z-flex liner run to the 3 ft long b-vent that went through the roof from the water heater 12 ft away. It looked like a camel0 -
same matierial as chimney liners. it's ok as long as there is proper clearance to combustables and pitched0 -
Same Material?
Product sold as a Chimney Liner is backed by the manufacturer, and is Listed by a recognized agency, for its intended application. Criteria imposed for Listing include thickness of material, permissable alloys, joint/lock design, bend radius, puncture resistance, thermal performance and adaptablility to appliance flues. Don't believe you have the same backing if you use dryer vent as a combustion vent.0 -
same material??
umm....I hope the liner doesn't have that horrible seam that unzips if you look at it wrong...
Aren't chimney liners SS not aluminum?
Matt0 -
MATERIAL
Gas uses aluminim liners while oil uses SS liners.
Neither use dryer vent.......;0)0 -
right.....
Sure it's the same material, ALUMINUM. The "sameness" ends at 1/2 the wall thickness and NO approval for this application. When was the last time your Dryer vented at 450F ? I'm betting your wife would howl about THAT shrinkage !0 -
I saw home HD install hydronic expansion tanks on domestic line to water heater on three occassions.0
- 86.6K THE MAIN WALL
- 54 Biomass
- 98 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 931 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 42 Industry Classes
- 48 Job Opportunities
