Ground source heat pump manufacturers?
Chuck_7
Chuck_7 Member Posts: 71
I know about Climate Master, Econar, and Water Furnace. Any others out there (esp. in western NY)? Anything about the above that I should know about (good or bad)?
  • Troy_3
    Troy_3 Member Posts: 479
    Econar
    Is what we use and we are in WNY. We have a couple going in now with radiant heat and high velocity a/c. If you want to see call me- Troy 716-913-4166. We have chosen Econar because of the heating efficiency in our cold climate. Most of the manufacturers shine on the a/c side but do poorly in the heat side. Our primary need is heat.
  • Brian_24
    Brian_24 Member Posts: 76
    ecr ground source heat pumps
    I have been using ecr's equipment with great sucess. It is a direct exchange system. No problems with water quality and less parts to worry about. Check them out at ecrtech.com or heawarsaw.com
  • Brian_24
  • Brad White_2
    Brad White_2 Member Posts: 188
    McQuay
    Has a line of GWSHP's
  • jwade55_3
    jwade55_3 Member Posts: 166
    Others
    Florida Heat Pump
    Hydrodelta
    Carrier
    J
  • Don in IA
    Don in IA Member Posts: 7
    Whatever brand you use get training on it. Went thru WaterFurnace service and install training in the mid '90's. Can troubleshoot very quickly and tell you if water side or refrigerant side in under 5 minutes using only water press guage and temp probe.
    Not that other brands are bad, I would like them as much if had the same training for them as have had for WF.
    Don
  • Ken D.
    Ken D. Member Posts: 836
    Geo-Thermal
    We use much Florida Heat Pump (FHP) and like them very much. Also use ECR to a lesser extent.Depends on the budget.
