weil/phase 3 tank
kevin coppinger_4
Member Posts: 2,124
it used to be that you could in a tight place place a Phase 3 indirect on it's side...they may have even had a bracket to hold it....since the Weil-Mcl gold plus is practically the same unit .....can you still do this? I know the output would be reduced. have a unique job where headroom will be at a premium....kpc
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=323&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Can't you use
indirects made for horizontal applications like the Crown or Buderus models? I would think puting a vertical indirect on it's side would screw up the dip tube and create cross flow directly from the inflow to outflow ports, picking up little heat at all. A few makers have low-boy models also.0 -
The HL series
used to come with the 2 brackets for either wall mount or to lay on the floor . Like you said , output is reduced , I think something like 25 percent . You also need their special dip tube . I'm not sure if they still make the HL because we change them out with the Smart series whenever we get a leaker .
We just installed a Buderus indirect under a Buderus boiler . That looks like the way to go for tight space work - every connection is out the back , and it's relatively low to the ground . How low is the headroom Kevin ?
Ron
Pictures man! Show us the goods! Chris0 -
Dead batteries
And after seeing Heatboys latest project , I just might forget the batteries altogether . Instead of mounting the hardware to diamond plate , we made brackets out of 3/4 Taco flanges . Actually , it don't look too bad , I'm going to post a few questions about installing the
Buderus later , if you're around . I sure could use some help .0 -
yes I could...
but the Buderus Lt was $350 more.....a lot more $ than I wanted...All I have is 40"...I might just use the 40 gallon Hotwatermate by amtrol w/ a mixer, that gives me 37"( I was hoping to use a 50gal SSContender)...kpc
Price out a Crown Horizontal 40 gal MegaStore
I think it's less then the Buderus.0
- 85.7K THE MAIN WALL
- 50 Biomass
- 75 Chimneys & Flues
- 93 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 855 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.6K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
