Hartford loop?
JM_2
JM_2 Member Posts: 108
When mesuring for Hartford loop conection do you place the CENTER of the 1 1/4" loop at 2" below the normal waterline, or should the whole loop be 2" below. The Burham manual makes it look like the center of the loop is at 2" below.
( which puts 5/8ths of the loop above 2" and 5/8ths below 2")
Thanks
