Which pipe dope to use?
Luis
Luis Member Posts: 20
Hello,
Which pipe dope should I use in redoing my near boiler piping as to avoid steam leaks? I purchased pro dope (gray) from Home Depot as it was listed to be used in steam. However, when I was removing the incorrectly installed piping, I noticed that the pipe dope used was white and with a thicker consistency than the one I purchased.
Thanks
Lus
  • Robert O'Connor_7
    Robert O'Connor_7 Member Posts: 688
    Pipe Dope...
    EXPANDO.......See thread below..Robert O'Connor/NJ
  • Luis
    pipe dope
    Robert,
    Would you recommend expando for 2" and 3" pipe? I read the thread and it appears that tread lock with teflon tape as well as expando is used on larger size piping like 4" and 5".
    Luis
  • Robert O'Connor_7
    luis...
    If you use "EXPANDO", the fitting will never leak nor will you ever take it apart, EVER! If you never did this kinda work before, you should stick with some other brand for it will be quicker and easier to fix mistakes..Robert O'Connor/NJ
  • tommyoil
    tommyoil Member Posts: 612
    Try
    Leak-Loc with a couple wraps of teflon and thats that. I promise you no leaks.
  • Luis
    You mean the white teflon tape, correct? Not the yellow type.
  • larry_9
    larry_9 Member Posts: 33
    dope
    there are alot of dopes out there. leak lock is ghood on most chemical progressing, expando is good for something that does not expand and contract. most teflon base dope will do just fine.
  • tommyoil
    YES
    Yes, the white teflon tape.
  • Ken D.
    Ken D. Member Posts: 836
    Pipe dope
    I have not had good luck with Pro Dope on steam. Hard set Rectorseal has worked. I am not sure of the Rectorseal product number as they have a number of formulations. Laco Slictite Teflon dope has also worked. In a pinch I have used a combination of white teflon tape and Rectorseal soft set with good results(Tape first and coat with RS). Expando is very good, but is not readily available around us. At least not among our patronized supply houses.
  • clammy
    clammy Member Posts: 3,242
    pipe dope
    On steam over 2 1/2 i use lampwick 2 strands and grip lite or regular grip have used this method for 20 years and hardly ever have leaks lamp wick remenber that stuff around way long time and you know something the stuff works, in germeny i saw heating tech using hemp fiber and paste of some sort they swore by that stuff .But lampwick has never fail a little more time consuming but on big stuff i believe it's the best peace clammy
    R.A. Calmbacher L.L.C. HVAC
    NJ Master HVAC Lic.
    Mahwah, NJ
