Need a conversion factor
Mark J Strawcutter
Member Posts: 625
Around here 2b limestone gravel (also known as #57 I think) is sold by the ton.
I need to know the volume of a ton of the stuff. The kid behind the counter at the gravel yard looked at me like I was from outer space when I asked :-)
Mark
Mark
100 pounds per cubic foot
is what I have found in a couple of places. This would work out to 20 cubic feet per ton, or a little less than a cubic yard.0 -
good point
probably should wait until a good drought so I get my money's worth :-)
But wet vs dry is probably a moot point given the fact that they don't actually weigh the stuff - just eyeball scoops and/or partial scoops with a front-loader. Probably get it pretty close, at least with small loads.
Then again, I remember getting a "half ton" of sand from them in a friend's 3/4 ton pick-up. Rear suspension bottomed out and I was sure we'd blow at least one tire getting it home. Tricky steering, too.
Mark0 -
Gravel pits sell by weight rather than volume because it is a more accurate measure of the material rather than eye balling a loader bucket. Also trucks hauling have to obey weight restrictions. When audited though the accountants measure stock piles by volume then convert to tonnage. A rainy season is a good season at the gravel pit:)0
