Need a conversion factor
Around here 2b limestone gravel (also known as #57 I think) is sold by the ton.
I need to know the volume of a ton of the stuff. The kid behind the counter at the gravel yard looked at me like I was from outer space when I asked :-)
Mark
  • Matt Clina
    Matt Clina Member Posts: 90
    100 pounds per cubic foot
    is what I have found in a couple of places. This would work out to 20 cubic feet per ton, or a little less than a cubic yard.
  • Mark J Strawcutter
    Mark J Strawcutter Member Posts: 625
    good point
    probably should wait until a good drought so I get my money's worth :-)
    But wet vs dry is probably a moot point given the fact that they don't actually weigh the stuff - just eyeball scoops and/or partial scoops with a front-loader. Probably get it pretty close, at least with small loads.
    Then again, I remember getting a "half ton" of sand from them in a friend's 3/4 ton pick-up. Rear suspension bottomed out and I was sure we'd blow at least one tire getting it home. Tricky steering, too.
    Mark
  • Gordy1
    Gordy1 Member Posts: 25
    Gravel pits sell by weight rather than volume because it is a more accurate measure of the material rather than eye balling a loader bucket. Also trucks hauling have to obey weight restrictions. When audited though the accountants measure stock piles by volume then convert to tonnage. A rainy season is a good season at the gravel pit:)
