high-tank toilets
Ray Landry
Ray Landry Member Posts: 203
Went to a call today where the customer wanted to restore his leaking high tank toilet.. the current one has got a leaking fill and flush valve. Found the curtain fill valve w/ no problems from watertown supply, but can't seem to locate the flush valve. It's by yankee manufacturing and unlike the common douglas fill valve, this one has gott an 1 1/2 flush tube connection. The douglas that I found @ watertown has got a 2" tube connection (which means making the hole in the copper pan and wooden tank bigger,IE; my last resort)
So, I'm basically wondering if anyone out there knows of any good supply houses around who may carry yankee flush valves??
  • bob young
    bob young Member Posts: 2,177
    HI-TANK
    DON'T KNOW IF THEY ARE STILL AVAILABLE BUT WE ALMOST NEVER CHANGED PARTS ON HIGH TANKS--SIMPLY REPLACED COMPLETE TANK . N.Y.C. PLUMBER
  • Robert O'Connor_7
    Robert O'Connor_7 Member Posts: 688
    flush valve?
    Can't you just resurface the valve seat. Sand it down and try it.,,Robert O'Connor/NJ
