Trip Waste
Linkzsgo
Member Posts: 6
To all the plumbers out there, I am looking for a self adjusting bath-tub trip waste & overflow. I have seen it advertized in MP over the years.
Thanks
Thanks
What exactly
do you mean by self adjusting? Robert O'Connor/NJ0 -
Not only what do you mean,
but why would anyone want a "self-adjusting" trip lever?
You set it - it works. Why would it need to be adjusted after being installed and adjusted at that time?
Further, adjust what? The throw? The height of the drain stop?
bath waste
GERBER,GERBER,GERBER ENGINEERED FOR THE PLUMBER --YOU CONNECT IT ,YOU SET ,IT IT WORKS AND DON'T LEAK. A ONE SHOT DEAL THAT WORKS PERFECTLY EVERY SINGLE TIME.0 -
gerber too
17 ga. brass. their awesome. bob
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"To learn more about this professional, click here to visit their ad in Find A Contractor.0 -
watco
Watco also makes a self adjusting tub waste.
Eventually all self adjusting strip their little snap ring and it's back to replacing.
I still prefer the central Brass 1655X... learn how to install them correctly and you will have no problem:-)
wheels0 -
Trip Waste Update...
We looking for a self adjusting bath-tub trip waste & overflow because we want to stop the call back on the new installs. If its Self adjusting it will adjust it self even if our tech forgets to.
Thanks
Bath Trip Waste
Steve, Thank for the info I will check into both the Watco and the Central Brass.
Forget?
Thats part of there job. Ajust the toilets, check water temp at faucets, bleed air out of water lines etc. etc., and oh yeah make sure the tub holds water.0 -
EJW's got a good point
If your guys aren't paying attention to minor (but important) details, maybe they're not the guys you want working for you. Then again, it seems that more and more new construction plumbers skip the details in the rush to "get it done." Speed rules in new work. I'm not saying all guys who do new work push speed over quality, but again, it seems the majority do.0 -
Pretty soon...
The water for the urinals will too go by the way side with the new waterless urinals. As far as trip levers go, why not try an all glued plastic one. We just did a small residential apartment building where I purchased the drain that comes with an American Standard Americast tub and they sent the overflow & shoe but you have to cut the pipe and glue it together, the trip was a wire/cable type... I was skeptical at first but it worked great..Robert O'Connor/NJ0 -
A bad batch
We must of had a bad batch of keeney trip wastes. We would make the adjustment and later it would fail. I've been thinking about going to toe taps.0 -
Ever try the Watco toe tap
tub drains? I have them on my tubs and they work great. No trip lever, linkage, hair catchers, etc. They flow a bit faster also without the stopper linkage and other stuff in the way.
They also use sch 40 glue tees and fittings, instead of slip joints, so the are very strong should someone jam a snake down em someday.
I also use them on my lav wastes, eliminates that extra knob and junk under the counter. This waste also allows me to use a nicer high neck faucet, like a Grohe bar faucet. Easier to get a drink in the middle of the night from a high neck lav faucet
hot rod
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 58 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
