Spring Checks
Alan(CaliforniaRadiant)Forbes
Member Posts: 1,243
Make sure they are rated for the temperature of your system. Brass seated ones are for high temperatures, but can chatter and drive everybody nuts.
Teflon or neoprene seated checks make less noise, but selection for temperature rating becomes more critical.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=53&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Springs Checks
Can Spring Check Valves be used in vertical piping.0 -
swing checks
Would swing checks be better? Placed in the horzontal piping.0 -
More on checks
We use the spring checks on both horizontal and vertical piping. We used to use swing checks and flow checks and had problems.
- 167 Indoor-Air Quality
