Steam Riser
brian_16
brian_16 Member Posts: 1
perhaps an easy question: A steam "riser" is a supply line that continues from floor to ceiling, continuing up to supply additional stories, such as in an apartment building. What is the name for a steam supply line that does not continue up to higher stories? is just a stub on the floor that is there to supply a single radiator? thanks
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,538
    Still a riser.
    I'd call it a riser to the first floor.
    Retired and loving it.
  • bob young
    bob young Member Posts: 2,177
    branch
    a branch line would be the correct piping term
  • DanHolohan
    Guess I got that one wrong.
  • bob young
    RISERS ,BRANCHES & CROTONS
    it takes a big man to stand corrected,Dan. i might not always be right but i am never wrong. lol
  • DanHolohan
    Heck,
    I'm wrong every day. Just ask The Lovely Marianne!
  • gerry gill
    gerry gill Member Posts: 3,078
    and if that branch turns vertical?
    what do you call that piece that sits vertical? to me its still a riser cause it has to have a different name cause it very likely will be a different size than the runout or branch..dont you think?
    gwgillplumbingandheating.com
  • bob young
    those damn risers
    usually a riser is the pipe that " rises " from one storey to the next. take-offs from tee's off the riser are called branches that supply all the various piping on one floor.a take-off from a horizontal overhead main is considered a branch even though it penetrates the ceiling.in my world anything other type references would be too confusing especially when confering with other mechanics. if i would tell one of my men to cut a tee into a riser i want to be sure he understands the procedure without my being present on the jobsite. wow, this is getting way too technical. lol its only rock n roll
