Steam Riser
brian_16
Member Posts: 1
perhaps an easy question: A steam "riser" is a supply line that continues from floor to ceiling, continuing up to supply additional stories, such as in an apartment building. What is the name for a steam supply line that does not continue up to higher stories? is just a stub on the floor that is there to supply a single radiator? thanks
Still a riser.
I'd call it a riser to the first floor.Retired and loving it.0 -
branch
a branch line would be the correct piping term0 -
Guess I got that one wrong.
;-)Retired and loving it.0 -
RISERS ,BRANCHES & CROTONS
it takes a big man to stand corrected,Dan. i might not always be right but i am never wrong. lol0 -
Heck,
I'm wrong every day. Just ask The Lovely Marianne!Retired and loving it.0 -
and if that branch turns vertical?
what do you call that piece that sits vertical? to me its still a riser cause it has to have a different name cause it very likely will be a different size than the runout or branch..dont you think?gwgillplumbingandheating.com
those damn risers
usually a riser is the pipe that " rises " from one storey to the next. take-offs from tee's off the riser are called branches that supply all the various piping on one floor.a take-off from a horizontal overhead main is considered a branch even though it penetrates the ceiling.in my world anything other type references would be too confusing especially when confering with other mechanics. if i would tell one of my men to cut a tee into a riser i want to be sure he understands the procedure without my being present on the jobsite. wow, this is getting way too technical. lol its only rock n roll0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
