Copper to Stainless
John Penwarden_3
Member Posts: 21
Question: I have a process heating/cooling system (shell & tube) heat exchanger that heats/cools process tanks through an external jacket. The norm here is to run copper to the tank area, then switch to SS in the "clean" area and connect to the SS tank. The temp range is 50 deg F to 180 deg F water temp. Would a dielectric union be needed for Copper to Stainless piping? I am thinking not, but have a bit uncertainty. My contractor is saying it's not needed. Any thoughts are greatly appreciated.
Correct,
No dielectric fitting is required for a stainless to copper connection.
Go for it
I'm not sure dielectrics live long at 180° F anyways!
We screw copper into stainless indirect tanks all the time.
Check with www.copper.org for an official blessing. They have compatability charts for disimilar metal connections.
hot rod
Stainless-to-Copper
A dielectric fitting is not needed for the aplication you described..Robert O'Connor/NJ0
- 167 Indoor-Air Quality
