changing the rough on baseboard
Wild Bill
Member Posts: 111
on my baseboard rough on a three-building apartment renovation that is my job. I thought I have seen in some trade magazine some type of Flexi-corrugated metal type fitting that is somewhat like a "Fluidmaster" except for baseboard connections. Copper fittings might be too time consuming, and I don't have the room for pex adapters.
Thanks...Bill H.
Thanks...Bill H.
Check with
Slant Fin. They have an expansion joint for HWBB that may fit.
Slant Fin
used to offer these. Do they still Noel or Tom?
hot rod
slant fin flex fittings
If you can find an old supply house and then someone remember where they are, you are in luck. I found a few in an off the main drag supply house in Kingston, New York. Bring pictures when you go looking. Ed0 -
They were not made for a short time.
They are back, again. Any Slant/Fin wholesaler can get them. They are on the shelf, ready to go.
They are listed in the radiation book, with baseboard.
Noel
Slant/Fin Corporation0 -
You can buy 3/4\"
copper flex water heater connectors at most plumbing supply stores also.
hot rod
- 167 Indoor-Air Quality
