Testing a LWCO on a Vapor Vac System
JACKAL
JACKAL Member Posts: 2
this is the thing on a steam system on 1 pipe you test the LWCO with the unit running and make sure the thing shut's down on loss of water and restarts when it refills to test the float assembly but if it's a Vapor Vac system when you try the flush the LWCO when it's running the air gets sucked in... how would you test the Safety or would you have to cool the thing down to flush it >??
