tridicator gauges
Dale_6
Dale_6 Member Posts: 2
Looking for a manufacturer of tridicator gauges in 0-60 PSI and 0-250 F temp range for use in a product we manufacture. We need short stem and 1/2"MPT back mount. The temp range and short stem seem are hard to find. We were purchasing a gauge from Munchkin boilers that worked well but they changed their design. There is no identification of any kind on those gauges. Any suppliers or reps out there?
  • BillW@honeywell
    BillW@honeywell Member Posts: 1,099
    We have he TDV040...
    It's a 1/2"npt, with a 1" probe, but 60-320 temp range. It's part of the former Sparco/Braukmann line, and is available from hydronic-oriented Honeywell distributors. You can get more info at http://hbctechlit.honeywell.com.
  • hr
    hr Member Posts: 6,106
    The beauty of this gauge
    is it has a well that allows you to change the gauge without dropping water or pressure. It's actually a 1/4" gauge in a 1/2" well.
    I like the simple face without altitude, which confuses many homeowners. The red for temperature and blue for pressure makes it more user friendly, also. much better than all black numbers.
    Vaillant used them years ago. I think Slant Fin now uses them. And I saw them at a Watts Regulator booth at a show recently. Probably Italian made?? :)
    hot rod
  • hr
    is it has a well to allow changing the gauge without a drain down or pressure release.
    I like the red and blue, and it is much easier to read without altitude numbers, also. Especially for homeowners!
    It's actually a 1/4" gauge with a 1/2" well.
    Valliant used them years ago. I think Slant Fin now uses them. I have seen them in the Watts Regulator booth at shows. Probably Italian made??
    Be nice if all the boiler manufactures used the same removable gauge :)
    hot rod
  • DaveC
    DaveC Member Posts: 201
    Doesn't look like any used here at Slant/Fin...
    IMIT is a manufacturer in Italy that might offer it.
  • John@Reliable_9
    John@Reliable_9 Member Posts: 122
  • tim smith_2
    tim smith_2 Member Posts: 184
    gauges
    Try Marshaltown gauges, they have appx a 1" insertion and 1/2" shank. Straight or angle pattern. Good luck, Tim.
