Need Help on Tank Vault pls
Einsiedler_2
Member Posts: 93
Gentlemen - would appreciate your input on the following scenario...
Customer building small home on acreage c/w a tank vault buried underground. size of vault = 9'x24'x6'high. residing in this vault are 3-only 350Gallon cold water Storage Tanks...
He wants to lay 1 loop of pex-al-pex under tanks to keep temps above freezing.. I am concerned with the load vs out put of 1 loop. I am thinking it would be more prudent to line perimeter of room with radiation/baseboard...
Just not sure just how bad the load is with these tanks.
any thoughts?
thanks in advance,
EINSIEDLER
any thoughts?
thanks in advance,
EINSIEDLER
*bump..*0 -
If The...
...vault is buried below the frost line, do you need any heat at all?0 -
agree with...............
Mr Conner AKA the mule skinner:)I have a small community that have several tanks in a vault.Freeze has not been an issue.
cheese0 -
thank you gentlemen..
thats what I needed to know.. I won't worry bout any Load for this vault then...
appreciate your input(s) once again.
You all have helped me & others considerably over several heating issues..
sincerely, your Northern Neighbor...
Einsielder
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 984 Plumbing
- 389 Solar
