beige baseboard
Randy Tibbits
Member Posts: 91
I have a job that my customer wants bone colored baseboard. I figure hey no problem, slant-fin is eggshell. Thats pretty close to bone. I call in to order it and it's no longer available. I call around and none of the supply houses I deal with has a baseboard this color. Are there any brands out there that would be close to this color? The guy is not fussy about it being exactly bone color.
Try your local
hardware store for a good flat spray on enamel0 -
Colors
I had 2 customers that sent the baseboard to a autobody shop for painting because they did'nt like the color.If its only a couple of pieces, it should'nt cost that much.
Andy Morgan
R. Morgan Mechanical, LLC0 -
Actually
I changed the lay of the land in my home some years ago.I had the original "Shell White" color your looking for.I changed my model 15 to multi-pak 80 and it was only available in the "Nu-White".But my wholesaler had spray cans of "Shell White" on the shelf.So I sprayed it myself.Fast and you really can't tell.Slant-Fin MAY special order the color for you.I do have Multi-Pak 80 end caps in that color if you need some.Noel from SF frequents here so maybe he'll give us the skinny.
cheese0 -
Wholesalers can still get paint for you.
Probably at a better price than the on-line version, too.
https://www.slantfin.com/baseboard-order.html
Noel0 -
Seeeeeeee
told you;)
cheese0 -
was into Metallic Blue in the 80's:)
spray painted thebase board hammerd metallic blue:) no , i wasnt hammered just thinking like an 80's kinda guy:)0 -
A similar situation...
While visiting one of the distributors a few weeks ago, I noticed some baseboard shells made of Corian or Swanstone to match the homeowner's countertops or shower stalls. They had different designs for the vents on top. If you are interested, drop me an email & I'll tell you where to get them. They might help to quell the "I don't like those ugly heating things" comments from the homeowner and also they are impervious to rust.0 -
Bill @honeywell....
That sounds like something i would be interested in getting the particulars or specs on, any jpg that you might post?0 -
Hey, Weez...
I saw them at Ridgewood Corporation's branch in Parsippany, NJ. Their number is 973 335 4446. Ask for the showroom. They are made for them by a local guy, as far as I know, and I thought they'd be perfect for baths or kitchen use.0 -
Thank you... might change the entire atmosphere
of a room...its a good thing to keep our eyes Open as we zoom along in Life;)0 -
colored baseboard
Rescom makes a bone colered baseboard that is a alumiunum hard baseboard panel is 7" high 1" thick and comes is 2-10 foot sections send me an email and I will give further info0
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 970 Plumbing
- 386 Solar
