Heatway tubing
Hi Guys...I have a customer who has a system that incorporates Heatway entran 3 into a radiant floor system(s). Part of the system is staple up and part slab. Last winter one loop stopped working. It was winter and I thought it was frozen...its May, still plugged...I even ran street pressure to it, just drips...I will have to run a heat x-chger to it because I tested some of the junk comming out and it is ferrous/magnetic... So much for an 02 barrier...Any way to get the line back up and running? its a 175' run of 3/8" tubing....tia kpc
