Radiant Heating Design Software
David Brown
Member Posts: 1
I have to do an in-floor radiant system for a large house complete with an indoor pool. Does anyone have any recommendations for software devoted to radiant heat design?
Dave Brown
Dave Brown
gwgillplumbingandheating.com
If you have not used one
I might suggest you work with your Wholesaler on this one. Most design software formats have a learning curve(subtle one's,too) which take time to take full advantage of their power. From the sound of the scope of your project, I suggest experience.
Jed0 -
Design Services
We would be happy to assist you. Call us on Monday 800-321-4739
Tim D.0 -
Try..............
Siggys.www.hydronicspro.com The free stuff will entice you:)
cheese0 -
Ya! but how long
will it take him to LEARN how to use it?!. The job might be well underway by then. Design software are amazing tools, but can lead to false conclusions if not applied correctly. Just "go get it" and "punch it out" ain't the answer if you don't have the foundation. I'm not as smart as most here on the Wall, but I know when to say when.
Jed
p.s. And this could very well be a marketing "teaser post" for Loop Cad.
p.p.s. Try "bundling" it with "Design Software Publishers"0 -
David
where are you located? Maybe someone here is near you. We use a couple different programs. There is a real learning curve to these programs. Real life experience can help a lot. Local knowledge helps too.0 -
heating software
www.wrightsoft.com0 -
It takes a long time to learn
We use several different proprietary design softwares (Wirsbo, Viega, Watts, Zurn, WrightSoft, LoopCad, and Siggy's HDS). There is definitely a learning curve. Each software has its own quirks and one simple "minor" mistake could really put you in a bad spot. I agree with the others. If you don't have experience with the software, get some help. Or at least have someone check your work.
Tom Meyer
Senior Designer/Trainer
Precision Hydronics Corp
www.precisionhydronics.com
