Need Quick Answer to Simple Question
Mike T., Swampeast MO
Member Posts: 6,928
Head loss per 100' of "typical" PEX in ½" and 3/8".
Am working on a sizing/application/initial balance computer program for Danfoss FHVs and some of you will know it off the top of your head I'm sure...
Thanks!
Thanks!
Head loss of pex.
What's your flow rate?0 -
ARGGH!!!
What the heqq was I thinking!!! I know MUCH better...
Link to table for "typical" PEX pressure drop?
Something tells me I'm going to have to end up with my "backwards" calculus for this program! (Backwards meaning I only realize it's calc. after I've done it...)
"Magic" delta-p is the goal of the programming as it's the delta-p that keeps head loss through all of the loops nearly identical regardless of loop size/length. (The FHVs have an initial adjustment where you "dial in" for a specific delta-p of the valve itself based on your flow and delta-t).
Of course this program will assume constant circulation, maintenance conditions and the ability of your construction to actually deliver the required BTUs to the floor...0
- 167 Indoor-Air Quality
