Need Quick Answer to Simple Question
Head loss per 100' of "typical" PEX in ½" and 3/8".
Am working on a sizing/application/initial balance computer program for Danfoss FHVs and some of you will know it off the top of your head I'm sure...
Thanks!
  • Rich Corcoran_18
    Rich Corcoran_18 Member Posts: 9
    Head loss of pex.
    What's your flow rate?
  • Mike T., Swampeast MO
    Mike T., Swampeast MO Member Posts: 6,928
    ARGGH!!!
    What the heqq was I thinking!!! I know MUCH better...
    Link to table for "typical" PEX pressure drop?
    Something tells me I'm going to have to end up with my "backwards" calculus for this program! (Backwards meaning I only realize it's calc. after I've done it...)
    "Magic" delta-p is the goal of the programming as it's the delta-p that keeps head loss through all of the loops nearly identical regardless of loop size/length. (The FHVs have an initial adjustment where you "dial in" for a specific delta-p of the valve itself based on your flow and delta-t).
    Of course this program will assume constant circulation, maintenance conditions and the ability of your construction to actually deliver the required BTUs to the floor...
