what is the reason for P/S piping?
R. Kalia
R. Kalia Member Posts: 349
What is the purpose of a secondary loop in a condensing system? Is it only to maintain a minimum flow rate through the boiler?
So if the pump is wired to maintain flow in the primary loop ALL the time (turning off only when the main power to the system is turned off), and the primary loop cannot be closed off completely and the flow rate always stays above the minimum rate needed by the boiler, then one doesn't need the secondary loop?
