new Munchkin models
R. Kalia
Member Posts: 349
...that they are changing the Munchkin cabinets that receive so much criticism for looking cheap.
A
A
a little birdie told me...
At the same time they will increase the modulation range, but I don't know how much.0 -
Tell the birdie...
Integrate the switch into the design so that it doesn't like like an afterthought. BTW, NTI is also working on a Trinity with an increased modulation range (5:1). I wonder if they are both using the same burning technology (as well as the same heat exchanger)?0 -
OK
The birdie said the switch issue was fixed. And that the new modulation is 5:1. Wouldn't confirm or deny that the new burner is the same as on Trinity, so probably it is the same.0
- 167 Indoor-Air Quality
