new Munchkin models
R. Kalia
R. Kalia Member Posts: 349
...that they are changing the Munchkin cabinets that receive so much criticism for looking cheap.
A
  • R. Kalia
    a little birdie told me...
    At the same time they will increase the modulation range, but I don't know how much.
  • Uni R
    Uni R Member Posts: 663
    Tell the birdie...
    Integrate the switch into the design so that it doesn't like like an afterthought. BTW, NTI is also working on a Trinity with an increased modulation range (5:1). I wonder if they are both using the same burning technology (as well as the same heat exchanger)?
  • R. Kalia
    OK
    The birdie said the switch issue was fixed. And that the new modulation is 5:1. Wouldn't confirm or deny that the new burner is the same as on Trinity, so probably it is the same.
