Steam Towel Rack
gehring
gehring Member Posts: 65
Does anyone know where I can find a steam heated towel rack?? I am remodeling a bathroom that already has a steam line to it and would like to add a steam-heated towel warmer. If there are none available then I would consider making my own, but would need a diagram or some suggestions.(e.g. 1" black iron then have it chrome plated?) FYI I have a one-pipe gravity system. Thanks.
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,703
    Go to:
    www.steamradiators.com
    Retired and loving it.
  • Dale
    Dale Member Posts: 1,317
    Clearance
    Steam pipes have a clearance to combustibles, usually 1". I guess it might be legal if your towels weren't combustible or if a orifice was installed to reduce heat and the component was ul or other wise listed. I can guess why no one sells them.
  • DanHolohan
    Take a look in the Library
    under Steam Heating. The first item. Thanks.
  • Frank M. Tricarico
    Frank M. Tricarico Member Posts: 25
    Look on the WEB under heated towel warmers. Most are electric but a few had hot water. Maybe if you search enough sites you can find "steam heated".
  • Christian Egli
    Christian Egli Member Posts: 277
    plate warmer
    What about those lovely old radiators that had a compartment with doors on it so that you had a plate warmer or better yet, a place to warm up your pyjama.
    My guess is that you could fit some towels in there and that the antique look could be quite nice.
