grundfoss pump with Infloor,Inc. mixer and relay
Bruce_8
Member Posts: 5
I have an Infloor, Inc. mixing unit for radiant heat.Model#ZC001. This has a Grundfoss pump attached and also has its own relay built in. I need a replacement mixing body as the one I have has frozen and split. Any information on where I can find one would be helpful. I lived get this, the better. Thanks
Infloor Zone Control
Infloor Heating Systems made these units but discontinued this model several years ago. Even if you could find a replacement body, the relay is no longer in production. Best direction to take is separate pump with built-in or separate relay, zone valve, and 3-way tempering valve, manual or automatic.
pump
Danfoss makes a nice little 1 zone pump package and also a 2-4 zone that might help you,there made with a nice cover and are prewired so you hook thermostat and plug in the panel nice and easy , comes in 30 or 50 mbh sizes
post here if you cant find them Nron0 -
infloor pump
we currently have a used pump body (plastic base) if interested email me. marc0 -
Thanks for the help. Have decided to install seperate mix valve and pump as the mixer in question is no longer available. Luckily for the homeowner, their insurance is going to pick up the cost of everything. Thanks again. Bruce0
