grundfoss pump with Infloor,Inc. mixer and relay
Bruce_8
Bruce_8 Member Posts: 5
I have an Infloor, Inc. mixing unit for radiant heat.Model#ZC001. This has a Grundfoss pump attached and also has its own relay built in. I need a replacement mixing body as the one I have has frozen and split. Any information on where I can find one would be helpful. I lived get this, the better. Thanks
  • t.speed
    t.speed Member Posts: 11
    Infloor Zone Control
    Infloor Heating Systems made these units but discontinued this model several years ago. Even if you could find a replacement body, the relay is no longer in production. Best direction to take is separate pump with built-in or separate relay, zone valve, and 3-way tempering valve, manual or automatic.
  • Nron_9
    Nron_9 Member Posts: 237
    pump
    Danfoss makes a nice little 1 zone pump package and also a 2-4 zone that might help you,there made with a nice cover and are prewired so you hook thermostat and plug in the panel nice and easy , comes in 30 or 50 mbh sizes
    post here if you cant find them Nron
  • marc
    marc Member Posts: 203
    infloor pump
    we currently have a used pump body (plastic base) if interested email me. marc
  • Bruce_8
    Thanks for the help. Have decided to install seperate mix valve and pump as the mixer in question is no longer available. Luckily for the homeowner, their insurance is going to pick up the cost of everything. Thanks again. Bruce
