Steam rads and hot water system
Alan_5
Member Posts: 4
I have an old house with a new addition. The old part has electric baseboards that I want to get rid of.
The new part has in-floor radionic heating.
The hot water distribution setup has a mixing valve for the lower temp in the floor loops. There is a direct connection for adding rads to replace the electric heaters in the old part. But baseboard rads are BUTT UGLY! My wife wanted the old style cast iron rads. I found some for sale locally, but since I did not know anything about them at the time, I believed what I was told, that they were for hot water use. It now seems that these are steam rads. There are 2 connections, at each end of the bottom tube. There is no upper tube. There is a threaded (1/4") plug about 2/3 up the side.
Question: Can I use these rads in some configuration?
Thanks
Thanks
No
problem. You will have to install a plug in the mid height vent hole and install a key bleeder in the upper most tapping, but that's no biggy. You might also check Burnham's radiators @ www.burnham.com/radiator/index.cfm
Nice stuff and real pretty.
steam rad conversion
Did you say No, or No problem ?
If No Problem, do I need a key bleeder at the top of each section. It seems that I should get all the air out of each section.
Would I have to restrict the water flow somehow so that it won't just pass right through? I guess the water in the section gets heated by convection?
Any help VERY appreciated.
Thanks0 -
Yes--Problem
Each section will have to have a bleed valve. Maybe do-able for one rad--but for many???
Without a bleeder on each section it would probably fill with water eventually--over MANY months/years--but the air problems in the meantime would likely be nightmarish.
You're certainly not the first to make this mistake so don't feel bad!0 -
Why not post a picture of one of them
here, we can tell you for sure!
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"All Steamed Up, Inc.
Consulting0
- 120 Geothermal
