Steam rads and hot water system
Alan_5
Alan_5 Member Posts: 4
I have an old house with a new addition. The old part has electric baseboards that I want to get rid of.
The new part has in-floor radionic heating.
The hot water distribution setup has a mixing valve for the lower temp in the floor loops. There is a direct connection for adding rads to replace the electric heaters in the old part. But baseboard rads are BUTT UGLY! My wife wanted the old style cast iron rads. I found some for sale locally, but since I did not know anything about them at the time, I believed what I was told, that they were for hot water use. It now seems that these are steam rads. There are 2 connections, at each end of the bottom tube. There is no upper tube. There is a threaded (1/4") plug about 2/3 up the side.
Question: Can I use these rads in some configuration?
  • Ken_8
    Ken_8 Member Posts: 1,640
    No
    problem. You will have to install a plug in the mid height vent hole and install a key bleeder in the upper most tapping, but that's no biggy. You might also check Burnham's radiators @ www.burnham.com/radiator/index.cfm
    Nice stuff and real pretty.
  • Alan_5
    steam rad conversion
    Did you say No, or No problem ?
    If No Problem, do I need a key bleeder at the top of each section. It seems that I should get all the air out of each section.
    Would I have to restrict the water flow somehow so that it won't just pass right through? I guess the water in the section gets heated by convection?
    Any help VERY appreciated.
  • Mike T., Swampeast MO
    Mike T., Swampeast MO Member Posts: 6,928
    Yes--Problem
    Each section will have to have a bleed valve. Maybe do-able for one rad--but for many???
    Without a bleeder on each section it would probably fill with water eventually--over MANY months/years--but the air problems in the meantime would likely be nightmarish.
    You're certainly not the first to make this mistake so don't feel bad!
    Steamhead Member Posts: 18,504
    Why not post a picture of one of them
    here, we can tell you for sure!
    Consulting
