chimney for oil boiler
Al Letellier
Al Letellier Member Posts: 781
Most masonry chimneys are 8" square flue but can vary. If you're building a new one, it has to be sized to the connected venting load. Check code manuals or manuf. minimun flue sizes for the equipment you are using.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=248&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"</A>
  • Dak
    Dak Member Posts: 6
    1. What size diameter is the standard chimney?
    2. What is the clearance requirement on the inside of the house?
    thanks
  • Andy Morgan_2
    Andy Morgan_2 Member Posts: 147
    For
    What size boiler? Clearance depends on manufacture.
    Can you provide us with more info?
    Andy Morgan
    R. Morgan Mechanical, LLC
